Reload Xrefs with single command?
Does anyone know if there is a single command to reload all xrefs? Or a command string that would do it?
Currently I have to either open the Drawing Explorer to do it, or enter -xref and several keystrokes on the command line. I would like to create a toolbar button for this as I frequently have to reload edited xrefs and would like to streamline the process.
Create a custom button with ^C^C-xref;reload;*;0
thank you Robt. That is exactly what I needed.0
I often use the File > Recent Files menu item to reopen the current drawing.0
dubble click Xref in drawing, (to open it, or makes it actual) and than use the Refedit bar, lowest icon, refcloseandsave. Or close both drawings and open them again.0
