Howdy, Stranger!
Jig. Additional panel with keyWords.
Hi!
I'm trying to make a Jig.
When running the standard command, we can see an additional panel with key words.
In my Jig this panel does not appear. :(
[code]PromptPointResult userFeedback = prompts.AcquirePoint("\nSpecify endpoint of arc or [Line/Undo]: ", "Line Undo");[/code]
How to display an additional panel with key words?
  • For the prompts on the command line, set CMDECHO = On.
    For the pop-up panel of options, set PROMPTMENU = 1 or higher (see Settings window).
Sign In or Register to comment.
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
