Dynamic dimension - first digit is not fully visibe
This is certainly not a general problem. Please raise a support request and attach a drawing you have this problem with. Our analysts will be glad to investigate.0
I have installed second one Bricscad v15.3 x64 on different PC without this "first-digit visibility".So - proably something in settings/bug.0
Hi, I am having all sorts of minor graphics problem with V16 that I have never seen before. on different machines. Today one of the guys showed me that he could not stretch multilines 0 and 90° any other angle worked nicely ( it has a fill that was broken out of three copied lines 1 worked) . Sometimes I can not see what is happening when editing mtext until I hit OK. Its difficult to edit blindly. And also I'm very frustrated about the pickbox disappearing as I have demonstrated in videos before. This seems like the same type of issue. Unfortunately I can rarely repeat the problems if I restart the CAD.I have never had these problems in the past. ( some of the guys say they have occasionally seen the pickbox back inV13) . Am I the only one experiencing this?
Patrik
Same problem in v15 x64 with disappearing mtext occasionally - blind edit ;].Sometimes pickbox (OSMODE) selfresets during drawing.Additionally I have in some files layer list - non alphabetically sorted.0
I have had a number of video issues recently on my v14. Specifically, often when I attempt to edit mtext, the edit window does not show any of my attempt to highlight text, or to type. But, I can type blindly and when I click OK, my edit was actually done. Exiting and restarting BricsCAD stops the problem, at least for a while.I had updated my Nvidia drivers through Windows update just before all this started.-Joe0
I should add that the other thing that goes away when this problem manifests itself, is that the dynamic display of a stretched item does not appear. But, the stretch does actually happen.-Joe0
