Model not updating
in Other
Pretty new at the CAD thing self teaching etc, but I have made a cultivator (agricultural machinery implement) which is still under development so there are many components and they are constantly changing. The issue I have is if a component is altered or something moved I save the altered component (same file) then go back to the main drawing and press update it doesn't update, the part stays the same but if I add it in another new model space it comes in with the alteration, is there a cache or something that I need to clear? Hope fully it is obvious and someone can help me!!
The BmUpdate command seems to broken in V16.2.15.
If your component is an unchanged or static component you can use the _EXPXREFS command to reload the file.
Else the only solution I can come up with is saving and reopening the assembly drawing.0 -
Oops. Addition:
If the file cannot be reloaded using the _EXPXREFS command you can reload via the Properties Bar (PB):
1. Preselect the component.
2. In the PB click in the 'File' field.
3. Click on the [...] button that has now become visible.
4. Select the correct file.0 -
The attach LISP includes a couple of functions that automate the reloading of XREFs. Hopefully this will help if you are having to do this a lot. Commands are:Jason Bourhill CAD Concepts
- XRELOAD to reload all attached xrefs.
- XRESET to reload all attached xrefs, and reset layer settings to those in the xref.
Have your raised a support request? Obviously needs to be fixed :-(
I have sent an SR.0
Update:
Today I have tried to reproduce the problem, but I was unable to do so (sadly I have lost the original test files). So I can only conclude that the BmInsert command works as it should. My apologies for any confusion I may have caused.
@ Sarah: Please send in an SR should you still experience issues with BmInsert.0
