Workspaces messed up
Somehow my workspaces got corrupted or messed up. If I start out in 2D mode then switch to 3D, mechanical, sheet metal the visual mode remains the same as 2D. Likewise if I start out 3D the visual mode is correct but switching to 2D the visual mode remains the same as 3D workspace. What am I missing here? Do I need to look into doing a re-install?
The behavior you are seeing is the 'out-of-the-box' standard. But you can customize it:
Customize > Workspaces tab > Expand nodes in left panel > Add a tool to the 'On Switch' nodes.
There are two predefined tools in the View section in the right panel: '2D Context' and '3D Context'.0 -
Addition:
Actually there are more predefined tools that can be used: '2D Wireframe', 'Wireframe' etc.0 -
Thanks Roy. Keep forgetting about the custom features of it, or I'm just lazy in my "old" age.
