PDF Export from Layout - problem
Hello,
I created layout from 2D drawing in model space. In layout drawing covers A4 paper just like I wanted, but when I export it to pdf, then exported pdf file is blank paper with small drawing in bottom. I have tried to change Export setting, but with no effect. Can you help me please?
Check on the lower left corner of the Page Setup dialog box. There is a control for scale (1:1, 1:10, etc.) and also a separate pair of text boxes that control the ratio of printed units to drawing units. I'm guessing that you need to adjust the printed-to-drawing ratio.0
In the Page Setup palette for that layout, set Plot Area = Layout and Scaling = 1:1.
Then hit the Print Preview button and see if it looks right.0
