Is it possible to hide dimensional constraint?
I know that AutoCAD permits the user to hide dimensional constraints. But, as far as I can tell, in BricsCAD v14, the only way to hide them is to create them on a new layer, and then turn that layer off.
I am trying to avoid adding more layers to contend with, since my assembly already has a very large number of layers. So, I wanted to double-check, in hopes that I overlooked something.
Can dimensional constraints be set to be hidden, like the other geometric constraints?
-Joe
Hi JoeIn V15 the DCDISPLAY command was introduced to control the display of dimensional constraints. In V14 this command is not supported yet, so the only solution to show/hide dimensional constraints is to create them on a dedicated layer.0
Note that in the new situation the dimensional constraints are also put on a dedicated layer (*ADSK_CONSTRAINTS). But this layer is hidden and does not appear in the _EXPLAYERS list.0
