Titleblock that rotates 90deg when inserted
I have somehow created a titleblock that rotates 90deg whenever is it is inserted. The drawing of the titleblock has the WCS set. I can't figure out how this problem started, or how to fix it. Any idea?
Attached is a somewhat simplified version of the problem drawing.
Thank you for any ideas.
-Joe
Dear JoeAFAIKS the drawing has a UCS which is rotated 90° CCW, which explains the rotated insertion.0
Ah, now I see it. I normally don't mess with the UCS in a 2D drawing. But, in this case I obviously did. Then, I presumed it was the WCS.Thank you for catching that for me. I probably spent over an hour trying to figure out what was going on.-Joe0
