Cannot save the file
When trying to save the drawing file from BricsCAD V 16 to server, the user is getting the attached error. He cannot save the drawing file locally or to server.
Tried with creating a new profile in BricsCAD. The ierror occurs even in admin login. there is no antivirus software  installed.  t
On the same system, they have AutoCAD and from AutoCAD 2007 they are able to save the drawings locally and to server.
Please suggest
  •  Hi,
    Tried with creating a new profile in BricsCAD. The error occurs even in administrator login. there is no antivirus software  installed.
    Please suggest
  • Hello,
    have you tried to open the drawing with _RECOVER, or to fix by _AUDIT ?
    Sometimes, a defect drawing can make problems during save operations (as the database defect becomes effective then).
    many greetings !
  •  AUDIT worked ..
