Qnew in inches, how to change this to mm
in Other
my quick new will open a new drawing in inches. I want this in metric (mm). How to change this?
Change the BASEFILE variable.0
Thank you for your response. Where to find the basefile variable?0
All variables can be found in the Settings dialog.Choose 'Settings' in the 'Settings' Menu and type 'basefile' in the search field.The Basefile variable sits under: Program Options/Files/Templates. Click the 'Template' settings field, then click the browse button to select an appropriate default drawing template.0
thank you Louis0
