Set PDF Creator as default PDF-printer
Hey
I would like to set PDF Creator as default PDF-printer, because when I publish sheet with the original PDF of Bricscad, the texts are unreadable.
Is it possible ?
Thx !
Make a start template drawing with the prefered printer. By the way you should ALWAYS start from a template. Half of the setting follow the drawing and you will spend a lot of time changing settings otherwise.0
