v16.2.15 Area Units
In v14 circles' areas are displayed in properties as:
2’-11”: 962.1128 sq. in. (6.6813 sq. ft.)
3’-0”: 1017.8760 sq. in. (7.0686 sq. ft.)
However, v16:
2’-11”: 962.1128 in²
3’-0”: 7.0686 ft²
Settings Area Units both Inches & Feet are checked.
Same phenomenon with rectangles.
Is there a setting I'm overlooking?
  • This new feature works differently. If you have checked Inches and Feet the area will be displayed in Inches if it is <=1000in2, above that the value will be displayed in ft2. Contrary to what the _SETTINGS dialog says, removing the AREAUNITS list is not possible.</div>
  • ...area will be displayed in Inches if it is <=1000in2, above that the value will be displayed in ft2.</p>
    Yes, I gleaned that.
    I just miss the "dual units" as previously displayed.
    Cheers
