Lengthen bug?
 I am trying to lengthen an oblique line (i.e. a line that's not horizontal or vertical), using the Increment option. The line seems to lengthen by a smaller distance than the increment I choose. Am I doing something wrong or is this a bug?
  •  Please check whether the line is perfectly horizontal. If not it seems as if the the added distance is shorter than you expected.
  •  Hello,
    I am using the Distance command to check the final length of the line and it is shorter than expected.
    This does not happen if the line I lengthen is vertical or horizontal, only when the line is at an angle.
  •  For clarity: when I write 'horizontal' I mean endpoints at the same Z-level.
  •  Oh my god, you are right! I feel so ashamed now. How can I delete this silly post?
