Hide certain layers in viewport
 how can I hide certain layers just in a specific viewport?
  • Double click in the VP to activate it.
    Start the _Layer command.
    Look for the 'VP Freeze' column.
    Alternatively you can use the _VpLayer command.
  •  Rather than hunt for the layer, I first select an object on that layer.  Then, that layer will be highlighted on the layer pull-down list. Then, you can click the icon to freeze that layer in just that viewport.
    -joe
