Disappearing xref
Hello,
I have trouble with xref files. When I am attaching xref first time in new drawing everything goes right but when I am trying to actualize it with new saved path, the older one disapper and the new one do not appear. I have only things which I have drawn.
Next problem i can show you in this screen which I have added. This problem occurs when I am trying to save drawing with xref files
https://www.easypaste.org/file/q6IVb4Tl/error.saving.jpg?lang=pl
Another and the last problem occurs when I am trying to unfreeze layers in drawing. When I want to exit this window, statement instantly shows.
https://www.easypaste.org/file/kPN6HzZI/unexpected.error.jpg?lang=pl
In the office we have 12 people working on bricscad and only I have this problem with drawings and xref files.
  • If all problems occur in the same dwg try using _AUDIT or perhaps _RECOVER.
  • Unfortunately problems occur in every drawing. After I am trying to actualize xref in the command window I have this statement:
    Object was permanently erased: (A7D86)
    Object was permanently erased: (A645D)
    Object was permanently erased: (A7D85)
  • In that case I advise you to send in a Support Request.
