Layers Toolbar - ACAD style
AutoCAD has a "Object Properties" Toolbar thuough which one can easily switch between layers. Icad doesnt have that "drop-down" list kind of toolbar. Anybody know if such a toolbar can be downloaded from anywhere?Any help will be greatly appreciated.-Harshal
You may try the _EXPLAYERS command to see if it displays what you need, then make atool button for it....
If you "Right Click" on the "Status-Bar Layer-Name" at the bottom of the screan a list of layers will roll up that you can choose from, If you "double left clik" it will pop up the Explorer Layer list, You can right and left click all over the status bar and get direct access to some usfull things..
hey thanks dez, that tip helps a lot.Harshal
