-P -Pan Snapping NOT working in version 17
in Other
Anyone else have this problem?
I need to move the contents of a viewport by a specified amount...... But NO snapping capability is available with -Pan..
All a can do is real-time panning..
Dear Jack,
in newer V17 versions (I tested with V17.1.10) the PAN commands were adjusted :
"PAN" switches to realtime pan, when in interactive (not programmed) mode
"-PAN" uses the classic approach, here you can snap ...
The default abbreviations (default.pgp) have been adjusted as well :
"P" => PAN
"-P" => -PAN
please try with actual V17 version ...
many greetings !0
