Xref nested endlessly
I have the problem, that i referenced a file "Projekt" in the drawing "balkon" and referenced "balkon" in "keller".
now when i open "keller" it shows me that "projekt" is missing (due to renaming) but i cant change the path since it is nested from "balkon".
So i open "balkon" and try to change it but it tells me again i cant change it. Apparently it thinks its nested from "keller"?
Anybody can help?
Also in the picture "balkon" you can see that he is referencing "Keller" two times. anyway to change that?
Cheers
Anybody can help?
Cheers
It works again. dont ask me why exactly. I renamed all the "keller"-references to point to a blank drawing. then i was able to change the path of the before nested "projekt"-drawing. then i re-referenced the correct "keller"-drawings.
I did this for all 3 files. Then i ran audit on all of them.
I still couldnt edit the nested "projekt" in any of the 3 drawings after doing that but at least i had the right files together again.
But now, 30min later into working i suddenly recognised that everything is working fine, i can edit the "projekt"-reference again!0
