SAVEFILEPATH & MOVEBAK v17
When setting both to point to a desired directory, the SV$ & bak files are still saved in the default C:\users\user\AppData\Local\Temp\Bricscad\
Is there a workaround?
  • When setting both to point to a desired directory, the SV$ & bak files are still saved in the default C:\users\user\AppData\Local\Temp\Bricscad\
    did you use the expresstools for the V17?
    Because in the V16 there was a timing bug while fireing the Reactors. But in the v17 its working fine.
  • did you use the expresstools for the V17?
    ...But in the v17 its working fine.
    Yes, I'm using the latest (excellent) v17 Express Tools.
  • have you set an path where to store the '*.bak files? (using the command 'movebak')
    If you save an opened and changed file there will be the command echo '(MOVEBACK_DOit_now)T' at the commandline prompted. Did you regoniced this?
    Yes, a path has been saved using MOVEBAK.
    No, there is no command echo MOVEBACK_DOit_now on the command line.
  • please replace the old file with this new one in the Expresstools Folder. Did you realy downloaded the Expresstools for the v17? I Did'nt got any Problem, while trying this out.
    Regards Martin
    Acetutil.des
    Regards Martin
    Hi Martin
    Yes, absolutely running the v17 Expresstools.
    Replacing the .des file with the latest yields "Cannot load ACETUTIL.des" upon BCad launch.
    Regards
  • :hmm it seems there was going something wrong, while comiling the file.
    please try this new attached one.
    Acetutil.des
  • Excellent.
    It appears now to work as advertised.
    I appreciate your tenacity.
    (Now if I can only figure out the SV$ save file path)
    Cheers
