Section hatching
When you create a section from an isometric view, the hatchs appears aligned with the view and not with the forms. How can we solve it?
Hi Guillermo,I think this is a message for the Architecturals forum.The answer is that the surface hatching can only be used when the section plane is vertical (elevations, cross sections, plans). In 'isometric' sections it's better to use surface fill instead.Regards,Louis
