How to edit scaled block
I have created block in AutoCAD and scaled it with different X and Y values.
Now I would like to edit it in Briscad.
I'm getting this error :
[code]** Cannot REFEDIT a non-uniformly scaled block ** [/code]
Not supported?
Not supported?
Temporarily insert the same block elsewhere with uniform scale, and REFEDIT that. Remove again once you've finished.
Regards,Jason Bourhill
