Bank Gothic font error
Intellicad does not render properly the Bank Gothic font. It is only 70% the size it should be. This makes it difficult to use the font in a mixed Autocad/Intellicad environment.
  • Bank Gothic is a Microsoft Windows Tru-type font rather than a vector-based CAD font (such as .shx)Because they are not vector-based, Tru-type fonts do not scale properly in vector-based CAD programs. Close approximation is the best you can expect.For EXACT scaling of fonts, use vector-based CAD fonts.
  • My problem is it is only 70% the size using the exact same style description as in Acad. This is not the case with other true-type fonts I have tested.
