Centre line command?
Does Bricscad have a command for inserting a center-line between parallel and non-parallel lines? If so does it work with rays and infinite lines as well as drawn lines? I use various work-rounds but it would be nice to have an in-built facility.
Hi Andrew,
If you don't mind using a third-party tools, we have exactly the same command GT_CENTLINE in GeoTools which is used by several utility clients of ours who need center-line digitizing in different situations.
Willing to improve/tweak the command based on specific inputs and requirements.
Best Regards
Rakesh Rao
Hi Andrew,
Best Regards
Rakesh Rao
