V3.2.0001 LEADER dimensioning Bug
With the new leader command, where the line is one entity, if you mirror the leader and text the tail (short horizontal line between the leader and text) disappears. If you UNDO the tail is still gone (so it did not really undo). If you use STRETCH to move the dimension to the other side, effectively mirroring it (not always appropriate esp. if you need to mirror a whole part to make a left hand of a right and there are several leaders in the drawing) then the text is not on the desired side of the tail and needs to be moved independent of the STRETCH. And the text justification is technically not right and needs to be edited.Of course it you EXPLODE the leader (thus returning it to how it was before the command was improved) the text location, justification and tail mirror just fine.Bug dates back to V3.1
Bug still not addressed as of v3.3.0003.
