V3.2.0001 STRETCH command Bug
If you stretch a broken line type (HIDDEN, DASHED, PHANTOM, etc.) and your selection window crosses the line in a broken section, the line is ”moved” instead of “stretched”. One often finds it necessary to use a crossing poly line or a zoom (or both) to insure crossing the solid part of the line.Bug dates back to V2.2.0010 or earlier.
