V3.2.0001 MTEXT Justification Bug
When an MTEXT entity with middle center justification has one line of text, the vertical center is centered with the text (as it should be).When there are two lines of text it is centered between the lines (as it should be).When there are three lines it centers between the first and second lines instead of centering on the second (middle) line of text.When there are four lines of text it is centered between the second and third lines (as it should be).When there are five or more lines it centers between the second and third lines instead of centering on the middle line of text or between the two middle lines (if even number of lines).This forces one to move the text up on a vertical dimension to fit between the dimension lines (which are created with the right gap for the actual number of lines but the text is not centered on them, the insert point is).Some other justifications also behave oddly.Bug dates back to V2.2.0010 or earlier.
Bug still not addressed as of v3.3.0003.
