bricscad default application on linux to open *.dwg files
I'm interested in the same issue...Dolphin browser under plasma kde 5.I tried to associate the bricscad.sh script to .dwg files, but nothing happen when double click on such files.0
I just handled how to successfully associate dwg files to bricscad.Just open your DE default files association GUI editor.Find or add the .dwg file type.Add application: /path/to/bricscad/bricscah.sh (to be associated to .dwg extension)Important: change the default working path to: /path/to/bricscad/If you still have problems, check the options to launch bricscad in terminal and keep it open. There you'll ready what kind of issue are you facing on.0
thank for your reply but i dont understand what to do.. I'm using Antergos x64 and i've read the forums both antergos and arch and didnt find any solution.! i want to right mouse click and in the submenu i want to add bricscad icon check photo attached
default apps.jpg0 -
thank for your reply but i dont understand what to do.. I'm using Antergos x64 and i've read the forums both antergos and arch and didnt find any solution.! i want to right mouse click and in the submenu i want to add bricscad icon check photo attachedI'm not a GNOME user, so I'm sorry I can't help you in detail.You should have a .desktop file to lunch Bricscad, like this (check paths):[code][Desktop Entry]Comment=Exec=/opt/BricsCAD/bricscad.shGenericName[it_IT]=GenericName=MimeType=image/vnd.dwg;Name[it_IT]=bricscad.shName=bricscad.shNoDisplay=truePath=/opt/BricsCAD/StartupNotify=trueTerminal=falseTerminalOptions=\s--nocloseType=ApplicationX-DBUS-ServiceName=X-DBUS-StartupType=noneX-KDE-SubstituteUID=falseX-KDE-Username=[/code]It can be created manually or with the GUI (but I don't know in GNOME which is).I found it under ~/.local/share/applications/0
ok i got is working…
- create a folder and put the 4 files in it
I)BricsCAD-V16-dwg.xml
contains the following…:
[code]<?xml version=“1.0” encoding=“UTF-8”?>http://www.freedesktop.org/standards/shared-mime-info’> [/code]
CAD Drawing
II) BricsCAD-V16-dwt.xml contains the following:
CAD DrawingIII)BricsCAD-V16-dxf.xml contains the following:
CAD Drawingand last but not least the shortcut itself Bricscad-V16.desktop contains the following:
Name=Bricscad-V16
GenericName=Bricscad
Comment=Bricscad V16
Exec=/home//BricsCAD-V16/bricscad.sh
NoDisplay=true
StartupNotify=true
Terminal=false
TerminalOptions=\s–noclose
Icon=/home//.local/share/icons/bricscad.png
Type=Application
X-DBUS-ServiceName=
X-KDE-Username=
MimeType=image/vnd.dwg;image/vnd.dwt;image/vnd.dxf;application-vnd.BricsCAD-V16-dwg;application-vnd.BricsCAD-V16-dwt;application-vnd.BricsCAD-V16-dxfCategories=Application;Graphics;2DGraphics;RasterGraphics;[/code]
ok bear with me and open the terminal and put those commands
sudo xdg-mime install --novendor --mode system "BricsCAD-V16-dwg.xml"
sudo xdg-mime install --novendor --mode system "BricsCAD-V16-dwt.xml"
sudo xdg-mime install --novendor --mode system “BricsCAD-V16-dxf.xml”for the next commands on the terminal i suggest to move the Bricscad-V16.desktop in the folder
/home//.local/share/applications/
sudo xdg-desktop-menu install --novendor --mode system "Bricscad-V16.desktop"
sudo [ -x /usr/sbin/update-mime ] && /usr/sbin/update-mime ]and finally the result should be just like mine…
20170127_145106.jpg0 - create a folder and put the 4 files in it
CAD Drawing
[Desktop Entry]
Name=Bricscad-V16
Exec=/home/linux/BricsCAD-V16/bricscad.sh
NoDisplay=true
StartupNotify=true
Terminal=false
Icon=/home/linux/.local/share/icons/bricscad.png
Type=Application
X-DBUS-ServiceName=
X-KDE-Username=
Categories=Application;Graphics;2DGraphics;RasterGraphics;ok bear with me and open the terminal and put those commands
i tried and i tried but the xml contents arent showing up.!check in this link i posted the answer as well!!0
