Transfer BricsCAD configuration settings from old computer to new computer
I am setting up a new computer that will be running BricsCAD V16. I have a older computer that is running BricsCAD V15 and I have it configured the way I like. I want to see if there is a way to create a configuration file from the old computer that I can be transferred on to the new computer so I do not have to go back through and get things setup the way I currently have the old computer setup?
Thanks in advance
Matt
Matt,
In V15 you can use the profile manager to create a user profile and then export the profile. Then in V16 you can import the user profile that you just created via the profile manager. To access the profile manager you can type "profilemanager" at the command line or in the pull downs select Tools > User Profile Manager.
Hope this is what you are looking for....
Many Thanks,
Kevin0 -
Thank You Kevin for your help. That did the trick.Matt0
