DWF doesn't export images?
 Hello you all.
I'm using Bricscad Version 17.1.07 (x64) revision 45745.
I'm trying to export a DWG with some images attached.
When I try to export my dwg to DWF, using the command dwfout, don't know what's the problem, but all the images are not there, just an empty space.
The images are inserted in ModelSpace, with the extension .jpg with 640x480 with full path.
Any ideas?
Clips are attached.
Thank you,
Kind regards.
  • Looks to be a bug in BricsCAD. The image is only included from the space that the DWF EXPORT is run from. Attach an example with the same image attached in Mspace and Pspace. EXPORT from Pspace only includes the Pspace image, Mspace image is missed.
    Based on your example image, a workaround maybe to shift the images to Pspace. CHSPACE is a quick way to achieve this.
    DWF-Image.zipDWF-Image.dwf
