Deleting / merge double lines
I have a drawing with two layer (lines). I need to calculate the total length of the lines.
The problem is that some of the lines overlap. So when I calculate the Sum, the length is to long.
How can I merge/delete the overlap?
Can somebody help me?
Use the OVERKILL command to delete/join overlapping and double entities.0
