Text editor mask color
How do you globally change the mask color in the text format editor? See the attached image, I'm using the latest V16. I've went thru all the options under settings but nothing seems to affect it.
There is no global setting for the mtext background mask color.
If you want to change all existing mtext entities:
1. Use QuickSelect to filter all mtext entities with and/or without a mask.
2. Apply a new setting by clicking in the appropriate field in the Properties Bar.0 -
Perhaps in the future releases they can add a "global toggle" for this. Thanks for responding!0
