Refedit nested blocks jumping like Autocad
I seem to remember, that in Autocad you have been able to double click on another block entity from inside a block (nested or not) and it jumps to it?
I cant seem to do it Bricscad. You always have to close the reference, double click on the nested object, select the nesting level and go inside again.
Is there a Way?
cheers
  •  also:
    the cartouche of the drawing when this contains attributes, Bricscad can not edit the block cause it will always jump to the
    attribute texts.
  • This is normal behaviour and is the same in autocad. You have to open attribute blocks with _refedit.
