Moment of Inertia
in Other
Dear Friends,
I am trying to calculate "moment of inertia" for complex shapes like AutoCAD mechanical "AMINERTIA”.
But am not able to calculate the "moment of inertia".
I try to lot of ways but I can’t find the solution.
please give your suggestions to solve this problem.
Note :please refer the attached drawing File
Thank you Friends,
Nathan.
One of possible ways:1) convert your shape to REGION2) use SUBTRACT to exclude hole from the outside shape3)call MASSPROP and look for cendroid values4)MOVE region by negative values of centroid coordinates5)call MASSPROP again to check for moment of Inertia. Note, centroid coordinates must be 0,00
Personally, I find my moment of inertia is very easy to calculate. It is the greatest when I attempt to wake up in the mornings. I calculate that I can hit the snooze button on my alarm 3 times before I can overcome my personal inertia and avoid being late for work. :)-Joe0
One of possible ways:1) convert your shape to REGION2) use SUBTRACT to exclude hole from the outside shape3)call MASSPROP and look for cendroid values4)MOVE region by negative values of centroid coordinates5)call MASSPROP again to check for moment of Inertia. Note, centroid coordinates must be 0,0Dear Friend,Thank you for your Immediate reply.I followed your steps Manually in Bricscad, it works as my expectation.I have an another doubt regarding the same,how to perform SUBTRACT operation in Brx with c++.please give your suggestion.Thank you Friend.Nathan0
Hello Nathan,Please check this sample[code]AcDb3dSolid * pBlank = new AcDb3dSolid();pBlank->createBox(10.0, 10.0, 10.0);AcDb3dSolid * pTool = new AcDb3dSolid();pTool->createBox(5.0, 5.0, 5.0);pBlank->booleanOper(AcDb::kBoolSubtract, pTool);delete pTool;pTool = nullptr;AcDbDatabase* pDb = acdbCurDwg();AcDbBlockTableRecord * pMS = openModelSpace(AcDb::kForWrite, pDb);pMS->appendAcDbEntity(pBlank);pMS->close();pMS = nullptr;pBlank->close();pBlank = nullptr;[/code]Best regards,Egor0
Hello Nathan,Please check this sampleAcDb3dSolid * pBlank = new AcDb3dSolid();pBlank->createBox(10.0, 10.0, 10.0);AcDb3dSolid * pTool = new AcDb3dSolid();pTool->createBox(5.0, 5.0, 5.0);pBlank->booleanOper(AcDb::kBoolSubtract, pTool);delete pTool;pTool = nullptr;AcDbDatabase* pDb = acdbCurDwg();AcDbBlockTableRecord * pMS = openModelSpace(AcDb::kForWrite, pDb);pMS->appendAcDbEntity(pBlank);pMS->close();pMS = nullptr;pBlank->close();pBlank = nullptr;Best regards,EgorDear Friend,Thank you for your immediate reply.I tried as you said,It works as my expectation.Thank you for your suggestion,Nathan0
