Ribbon and menu's gone
I use a zbook 17 g2 from HP
This unit has a SSD from sandisk. SD6PP4M-256G-1006
I saw updates for this ssd and other hardware but IT did not installed these updates.
Data corruption; pst file damaged from outlook, ok deleted and created new.
But Bricscad hanged the entire system suddenly , the only solution was a forced shutdown (power knob)
The laptop started fine, but Bricscad's default.cui is damaged, when opened with notepad+ completely empty.
Bricscad can start but no ribbon and no menu's.
IT will check this laptop, but that means a re-install , what is the command to deactivate the license so that we can activate
the license again later?
Note: so no ribbon or classic menu. or can you send a default.cui file to stefaan.codde@sanitechniek.be
Have you tried?:
_Customize > Revert to defaults...
This will restore the default.cui from the UserDataCache.0 -
Not a fault of Bricscad: default.cui was corrupt, file empty and wrong size reported by windows.I extracted the Bricscad exe to copy this file again then restarted bricscad and the menu's are back.Firmware bug ssd which is solved now.0
