In current DWG, how to insert all Layouts from another DWG file
AutoCad Lisp Command: (command "LAYOUT" "t" "W:\\ACADGRAC\\Template\\Skice.dwg" "*")
Bricscad Lisp Command: ??????????????????????????????
The problem is that BricsCad not recognized Joker "*"
Thanks0
The Template option of the Layout command allows to import a selection or all layouts of another drawing.Right click a layout, then choose 'From Template...' in the context menu.0
OK, I’m familiar with that.
I am writing LISP program and this command is repeating several times in cycle and I need to use this command without Dialog.
This program works in Autocad and I’m customizing it for Bricscad.
What this command needs is some kind of Joker that would give a sign that I want all Layouts.
That way it could be compatible with one in Autocad.
Thank
Try using LayoutListFile to get a list of all PS layouts in the template.
Note: does not work if the template has been opened by a different user.
[code](defun KGA_Sys_ApplyAlt (expr varLst)
(not (vl-catch-all-error-p (vl-catch-all-apply expr varLst)))
(defun KGA_Sys_ImportOpen (fnm / acadObj fnmFound odbxObj)
(if
(and
(setq fnmFound (findfile fnm))
(vl-string-translate "\\" "/" (strcase fnmFound))
(vl-string-translate "\\" "/" (setq fnm (strcase fnm)))
(setq acadObj (vlax-get-acad-object))
(cond
(vl-some
'(lambda (docObj) (if (= (strcase (vla-get-fullname docObj)) fnm) docObj))
(vle-collection->list (vla-get-documents acadObj))
(and
(setq odbxObj (vla-getinterfaceobject acadObj "objectdbx.axdbdocument"))
(KGA_Sys_ApplyAlt 'vla-open (list odbxObj fnm))
odbxObj
; (LAYOUTLISTFILE "D:\\Test\\Lyt.dwg")
(defun LayoutListFile (fnm / doc lst)
(if (setq doc (KGA_Sys_ImportOpen fnm))
(progn
(setq lst
(vl-remove
nil
(mapcar
'(lambda (lyt)
(if (= :vlax-false (vla-get-modeltype lyt)) (vla-get-name lyt))
(vle-collection->list (vla-get-layouts doc))
(vlax-release-object doc)
(gc)
lst
)[/code]0 -
List Layouts from DWG works for me.
Many thanks Mr. Roy0
