How to make the drawing canves small
I've recieved from an Autocad user a drawing and its on a sheet that is based on coordinates.
The house is 11 m by 7.3m.
it comes very small in the layout I've made.
is it possible to make the model shit smaller in coordinates?
The model sheet is always in 1:1 scale, considering mm as drawing units.What you want do do is change the scale of your viewport. Try to go inside the viewport, (type MS or double click inside the viewport) and zoom to extend, Or set scale in the properties panel when selecting the viewport.And please look up in a dictionary the difference between sheet and shit in the English language.
The model sheet is always in 1:1 scale, considering mm as drawing units.What you want do do is change the scale of your viewport. Try to go inside the viewport, (type MS or double click inside the viewport) and zoom to extend, Or set scale in the properties panel when selecting the viewport.And please look up in a dictionary the difference between sheet and shit in the English language.thank you very much, and I do know the difference...... i was joking....
Howdy, Stranger!
