BricsCAD V17 Bugs with dynamic blocks & Mleaders
Morning all,
Not sure if anyone has experienced any issues with V17 compared to V16 but just wanted to post about what I've found and see if there is a quick fix.
One of my main problems are a number of stretch or array dynamic blocks that used to work perfectly in V16 but now have a number of glitches, such as not stretching correctly at all i.e stopping at certain points, and array blocks carrying on parts of the block but not others? Also with our Mleaders and filling in the text, if I copy and paste an Mleader and then attempt to edit the text, I cannot select all by the shortcut Ctrl+A. This again worked fine in V16, but for some reason now when I use the shortcut nothing happens and when I close the Mleader the command kicks in and selects everything in paperspace.
Just hoping anyone has experienced these and has any idea how to resolved before submitted to Bricsys properly.
Thanks all,
Rory
