Segmentation fault from libnvidia-glcore
I'm working with v16.2.14 (x64) révision 44207 with an 17.3 Mint (KDE powa) up-to-date and proprietary driver 367.57
When i want to copy or move a piece of draw, a crash appears.
[code]Program received signal SIGSEGV, Segmentation fault.
#0 0x00007fffc3ea13d8 in ?? () from /usr/lib/nvidia-367/libnvidia-glcore.so.367.57
#1 0x00007fffc3b76e7a in ?? () from /usr/lib/nvidia-367/libnvidia-glcore.so.367.57
#2 0x00007fffc3a4f0eb in ?? () from /usr/lib/nvidia-367/libnvidia-glcore.so.367.57
#3 0x00007fffc3b89916 in ?? () from /usr/lib/nvidia-367/libnvidia-glcore.so.367.57
#4 0x00007ffff053c7b0 in oa::RecFaceTrngText::playAsPlines(OGLBaseVectorizer*, OdGiConveyorGeometry*) const () from /opt/bricsys/bricscad/v16/libodapp.so
#5 0x00007ffff053cf01 in oa::RecFaceTrngText::play(OdGiConveyorGeometry*, OdGsBaseVectorizer*) const () from /opt/bricsys/bricscad/v16/libodapp.so
#6 0x00007ffff0552dbe in OGLBaseVectorizer::playMetafile(OdRxObject const*) () from /opt/bricsys/bricscad/v16/libodapp.so
#7 0x00007fffed3d2468 in OdGsBaseVectorizer::display(bool) () from /opt/bricsys/bricscad/v16/libTD_Gs.so
#8 0x00007fffed3ce2a8 in OdGsBaseVectorizer::updateViewport() () from /opt/bricsys/bricscad/v16/libTD_Gs.so
#9 0x00007fffed3fd29b in OdGsBaseVectorizeView::update() () from /opt/bricsys/bricscad/v16/libTD_Gs.so
#10 0x00007fffed3f8f00 in OdGsBaseVectorizeDevice::update(OdGsDCRect*) () from /opt/bricsys/bricscad/v16/libTD_Gs.so
#11 0x00007ffff055896d in oa::BaseVectorizeDevice::update(OdGsDCRect*) () from /opt/bricsys/bricscad/v16/libodapp.so
#12 0x00007ffff053ff62 in OdGsOpenGLVectorizeDevice::update(OdGsDCRect*) () from /opt/bricsys/bricscad/v16/libodapp.so
#13 0x00007ffff0555b18 in WxOGLHelperDevice::update(OdGsDCRect*) () from /opt/bricsys/bricscad/v16/libodapp.so
#14 0x00007ffff075ddea in oa::CDwgViewer::updateHelper(OdGsDevice*, wxDC*) () from /opt/bricsys/bricscad/v16/libodapp.so
#15 0x00007ffff0760a00 in oa::CDwgViewer::updateTracker(OdEdInputTracker&, wxWindow&, bool, bool, oa::GrRec*&) () from /opt/bricsys/bricscad/v16/libodapp.so
#16 0x00007ffff0ea2963 in ca::DragEnt::drawEntity(ca::DragContext&) () from /opt/bricsys/bricscad/v16/libcadapp.so
#17 0x00007ffff0ea2b29 in ca::DeTrackerPoint::update(ca::DragContext&, OdGePoint3d const&, int, bool) () from /opt/bricsys/bricscad/v16/libcadapp.so
#18 0x00007ffff0ea0d51 in ca::DragContext::dragStep(OdGePoint3d const&, int) () from /opt/bricsys/bricscad/v16/libcadapp.so
#19 0x00007ffff0ea127c in ca::DragContext::doOneDrag(OdGePoint3d const&, int) () from /opt/bricsys/bricscad/v16/libcadapp.so
#20 0x00007ffff0ea1444 in ca::DragContext::update(OdGePoint3d const&) () from /opt/bricsys/bricscad/v16/libcadapp.so
#21 0x00007ffff217da43 in wxg::WxgView::processMouseMovePoint(wxPoint&, bool) () from /opt/bricsys/bricscad/v16/libwxgui.so
#22 0x00007ffff217fd9f in wxg::WxgView::OnMouseMoveDefault(unsigned int, int, int) () from /opt/bricsys/bricscad/v16/libwxgui.so
#23 0x00007ffff0f134c2 in ca::RawInputSource::fireEvent(std::function const&, bool*) () from /opt/bricsys/bricscad/v16/libcadapp.so
#24 0x00007ffff0f13c7e in ca::RawInputSource::fireMouseMove(int, int, unsigned int) () from /opt/bricsys/bricscad/v16/libcadapp.so
#25 0x00007ffff451f56e in wxAppConsoleBase::CallEventHandler(wxEvtHandler*, wxEventFunctor&, wxEvent&) const () from /opt/bricsys/bricscad/v16/libwx_baseu-3.0.so
#26 0x00007ffff4655b42 in wxEvtHandler::ProcessEventIfMatchesId(wxEventTableEntryBase const&, wxEvtHandler*, wxEvent&) () from /opt/bricsys/bricscad/v16/libwx_baseu-3.0.so
#27 0x00007ffff4655bdb in wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*) () from /opt/bricsys/bricscad/v16/libwx_baseu-3.0.so
#28 0x00007ffff4655eda in wxEvtHandler::TryHereOnly(wxEvent&) () from /opt/bricsys/bricscad/v16/libwx_baseu-3.0.so
#29 0x00007ffff4655f53 in wxEvtHandler::ProcessEventLocally(wxEvent&) () from /opt/bricsys/bricscad/v16/libwx_baseu-3.0.so
#30 0x00007ffff4655fa9 in wxEvtHandler::ProcessEvent(wxEvent&) () from /opt/bricsys/bricscad/v16/libwx_baseu-3.0.so
#31 0x00007ffff4655a30 in wxEvtHandler::ProcessPendingEvents() () from /opt/bricsys/bricscad/v16/libwx_baseu-3.0.so
#32 0x00007ffff451f5ff in wxAppConsoleBase::ProcessPendingEvents() () from /opt/bricsys/bricscad/v16/libwx_baseu-3.0.so
#33 0x00007ffff3f0ad92 in wxApp::DoIdle() () from /opt/bricsys/bricscad/v16/libwx_gtk2u_core-3.0.so
#34 0x00007ffff3f0ae73 in wxapp_idle_callback () from /opt/bricsys/bricscad/v16/libwx_gtk2u_core-3.0.so
#35 0x00007fffea829ce5 in g_main_dispatch (context=0x9a6520) at /build/buildd/glib2.0-2.40.2/./glib/gmain.c:3064
#36 g_main_context_dispatch (context=context@entry=0x9a6520) at /build/buildd/glib2.0-2.40.2/./glib/gmain.c:3663
#37 0x00007fffea82a048 in g_main_context_iterate (context=0x9a6520, block=block@entry=1, dispatch=dispatch@entry=1, self=)
at /build/buildd/glib2.0-2.40.2/./glib/gmain.c:3734
#38 0x00007fffea82a30a in g_main_loop_run (loop=0x5d594c0) at /build/buildd/glib2.0-2.40.2/./glib/gmain.c:3928
#39 0x00007fffeba9e447 in gtk_main () from /usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0
#40 0x00007ffff3f17385 in wxGUIEventLoop::DoRun() () from /opt/bricsys/bricscad/v16/libwx_gtk2u_core-3.0.so
#41 0x00007ffff454f621 in wxEventLoopBase::Run() () from /opt/bricsys/bricscad/v16/libwx_baseu-3.0.so
#42 0x00007ffff451ff7d in wxAppConsoleBase::MainLoop() () from /opt/bricsys/bricscad/v16/libwx_baseu-3.0.so
#43 0x00007ffff45958ed in wxEntry(int&, wchar_t**) () from /opt/bricsys/bricscad/v16/libwx_baseu-3.0.so
#44 0x0000000000438aee in main ()
[/code]
[/code]
