2D constraints to a block
I am trying out v17, and attempting to create a drawing that makes extensive use of 2D constraints. However, I am unable to create a dimensional constraint between the end of a line object, and a block. This is true regardless of if I choose to snap to the end's of one of the lines in the block, or to the insertion point of the block.
I just confirmed that AutoCAD does permit you to use 2D constraints with blocks. Is this a limitation of BricsCAD? Attached is the example drawing.
-Joe
