Magical menus
Hi all,
Some menus disappear, for example, the export menu does not appear anymore but I have the question in the command line.
Toolbars also sometimes disappear, for example the "query" toolbar is no longer accessible. The only way I found to work around the problem is to change the workspace from 2D to 3D and then return to 2D
Best regards,
Cyril
  • I reply to myself ^^
    Access to the export menu can be restored by checking User Settings / Preferences / File Dialogue / "Display dialogue box"
    Thank you very much
