Stop Elements Uniting
 How do I stop elements from uniting/combining when generating sections. e.g. a roof firring piece sits on a roof joist (2 separate entities sharing a common face, but both timber and both part of a roof) but when a section is generated along the joist the resulting entity is drawn as one element. Any suggestions would be welcome.
Ralph
  • This is controlled by the 'Union Section' property of a Physical Material.
    For concrete or masonry this union is desirable, for timber it usually isn't...
  • Thanks Hans for the suggestion: this is indeed the way to control it, but unfortunately this feature does not work in the current release. We are on it, will be fixed as soon as possible.
    kind regards
    Pieter
