delete Zero length lines
I would like a simple script to erase lines with zero length. Any ideas?
Try this one:[code](foreach e (vle-selectionset->list(ssget "_X" (list (cons 0 "LINE"))))(if (equal (cdr (assoc 10 (entget e)))(cdr (assoc 11 (entget e)))0.00000001)(entdel e)))[/code]0
The code looks better if simply pasted...(foreach e (vle-selectionset->list(ssget "_X" (list (cons 0 "LINE"))))(if (equal (cdr (assoc 10 (entget e)))(cdr (assoc 11 (entget e)))0.00000001)(entdel e)))0
The code looks better if simply pasted...(foreach e (vle-selectionset->list(ssget "_X" (list (cons 0 "LINE"))))(if (equal (cdr (assoc 10 (entget e)))(cdr (assoc 11 (entget e)))0.00000001)(entdel e)))That's great thanks Vaidas. I'm only new to writing scripts and I can get it to work if I paste each line in the command line separately, but what will the text look like if I want to make a custom tool? I have this at the moment and it doesn't work. Is there something I'm doing wrong?(foreach e (vle-selectionset->list;(ssget "_X" (list;(cons 0 "LINE"))));(if (equal (cdr (assoc 10 (entget e)));(cdr (assoc 11 (entget e)));0.00000001;);(entdel e););)0
Hi Rowan,Remove all semicolons from your code because any text after semicolon is supposed as a comment.The simpliest way to use it is to save the code into YOUR.lsp file and load it with APPLOAD command.0
Ok so I've saved I pasted into a text file (See attachment Lisp1)Used APPLOAD to load it (see attachment Lisp2)How do I actually run the command. I did a bit of searching but couldn't find an answer.Thanks in advance!!!
Got it! had to add the folder to my support file search paths!0
Got it! had to add the folder to my support file search paths!Should have added:type:(load "0_lines")That single line of text can be saved as a tool0
