Mtext edit when zero width is used
When editing mtext with zero width it is aggravating to click near the end of a line & be dumped out of the edit mode. In Autocad even when the width is zero there is still an implied area around the mtext that is safe to click in & not end the edit command.
When there is a width assigned the problem goes away.
Would this be considered a bug or a feature?
