Is there a similiar command like "SELECTIONCYCLING" in AutoCAD in BricsCAD
Hi there,
Is there a similiar command like "SELECTIONCYCLING" in AutoCAD LT in BricsCAD V17?
Yep, there is. not sure what the system variable is, but you can use cycling by using the tab key while hovering above the overlapping lines. Unfortunately there doesnt seem to be a visual part like in Autocad, where you see the objects in a list.0
THX Benjamin.
I guess the visual part needs to turn on
the QUAD function.0 -
Yes, Quad shows you the objects type, but it doesnt show you a list like in dynamic mode in autocad, which comes in handy when you have more than 3 overlapping lines or more.
That would be a nice feature.0 -
Yes, sure. Why not.
Maybe with the next Release?0
