Why these commads doesn´t function in Bricscad "Classic"
Hello,
is there any special reason, why this function does not work in classic?
I believe these are what is known as 'command modifiers'. They work on all BC license levels but to use them a command must be active.0
Dear Halil'TK' and 'M2P' are available only when a command prompts to specify a point. TK allows to enter a series of temporary tracking points, M2P prompts you to specify two points, then calculates the midpoint between the two.Kind regards0
OK, you´re right. THX0
