Bricscad hangs on startup get : Xeres Error - fatal error at file c:\users\hoofdgebruiker\Appdata
Hallo,
sorry to have to write for help on second day off trial for crash , lock up when trying to learn understand Bricscad .
After selecting profile, any ,   selecting new file  I get this error window
Xeres Error - fatal error at file  c:\users\hoofdgebruiker\Appdata\Roaming...\default.cui , line 12349, char 29
How to solve?
Do i reinstall, redownload trial Bricscad ?  Will this be possible ?
Is there another way by resetting or deleting a file or selecting a different startup profile or handling.?
Thanks for your help.
Greetings
Dusselier Francis
  • Hello, Francis,
    normally, replace/overwrite your user menu file (.cui - as specified in error message) with a fresh copy from ./UserDataCache, under BricsCAD installatino folder ...
    should help normally.
    many greetings !
  • Hallo,
    thanks sir for your reply . It did solve the problem . Size in AppDataCache was twice the size in AppData\...   overwote it and Bricscad starts up normally again;
    Thanks , for the ultra fast reply.
    with kind regards
    Dusselier Francis
