Mtext edit problem when you click outside the text in zero width mtext
I sent this to tech support:
When editing mtext with zero width it is aggravating to click near the end of a line or in a blank line & be dumped out of the edit mode. In Autocad even when the width is zero there is still an implied area around the mtext that is safe to click in & not end the edit command.
When there is a width assigned the problem goes away.
Would this be considered a bug or a feature? :0
They said ACAD works this way now so it's a feature.
I said :
I'm afraid too if you are calling that a feature.
Nice to be compatible with Autocad but when they make a mistake BricCAD should not follow .
I would complain to ACAD too if I was still using there product.
