Express Tools help V16
in Other
Checked out the help file and see although it's in english there is no info under the subject titles, basically it's an "empty help". Am I missing something on the install process?
i don't think so. Here i attached you the both (english and german) help files. I checked them bevore and they well display the informations.0
Weird - they open up fine in windows but still "empty" in Bricscad. Is there a toggle somewhere in Settings?0
Bei mir startet die Express-Hilfe, aber ohne Inhalt.
Allerdings funktioniert bei mir das öffnen in Windows NICHT!
Gruß,
Dietz F.0 -
Möglicherweise was Windows schuld?
https://www.soft-ware.net/tipps/tipp59/Inhalt-einer-Windows-Hilfedatei-CHM-wird-nicht-angezeigt.asp0
