Change Text Case
Does Bricscad have a command to allow a user to toggle text case between LOWERCASE, UPPERCASE, and TITLECASE?
New user, first day so sorry if I am missing something obvious. Thanks for any help.
Assuming that you are using MTEXT then it's available from the menu that opens when you create and edit the text.
Regards,Jason Bourhill
Thanks for the response, I see the options for all uppercase, or all lowercase, but no option for title case, where the first letter of each word is capitalized. Any other suggestions?0
Expresstools -> tcase0
Dear Guys,
Yet another option (tool) to handle case management is from CADPower.
http://www.4d-technologies.com/cadpower/manual/text_tools.htm#CHCASE
In addition to Upper, Lower and Title case, The CP_CHCASE command also does word replacement using translation dictionaries.
Best Regards
Rakesh Rao
Smarter .dwg0
