Sub-levels of ribbon-menu is not displayed on small monitors
Find attached a self-made CUI where a ribbon has some sub-levels.
It works fine when the size of the entire Bricscad-window is wide enough to display everything. But decreasing the width of the windows forces all ribbons to collapse. That's a standard feature, but the problem of the attached example is that the lowest level of the commands is not displayed anymore.
I suppose that's more a bug than e feature?
Peter
